Ir para o conteúdo principal
HP Pavilion DV2160BR Wifi Adapter Replacement
O que você precisa
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: passo 1, imagem 1 %32 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: passo 1, imagem 2 %32
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: passo 2, imagem 1 %32 HP Pavilion DV2160BR Wifi Adapter Replacement: passo 2, imagem 2 %32
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: passo 3, imagem 1 %32 HP Pavilion DV2160BR Wifi Adapter Replacement: passo 3, imagem 2 %32
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Conclusão
Uma outra pessoa concluiu este guia.
Shannon
Membro desde: 04/11/13
55 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-66, Johann Spring 2013 Membro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 533
