Ir para o conteúdo principal
HP Pavilion DV2160BR Webcam Replacement
O que você precisa
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: passo 1, imagem 1 %32
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: passo 2, imagem 1 %32 HP Pavilion DV2160BR Webcam Replacement: passo 2, imagem 2 %32
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: passo 3, imagem 1 %32
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: passo 4, imagem 1 %32 HP Pavilion DV2160BR Webcam Replacement: passo 4, imagem 2 %32
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: passo 5, imagem 1 %32
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: passo 6, imagem 1 %32 HP Pavilion DV2160BR Webcam Replacement: passo 6, imagem 2 %32
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: passo 7, imagem 1 %32
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: passo 8, imagem 1 %32
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: passo 9, imagem 1 %32
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon MacDonald
Membro desde: 03/12/14
239 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 793
