Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Start with the bottom of the laptop facing up.
Locate the panel that is covering the RAM compartment.
Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
Lift up the panel that is by the end that held the screws. Set it aside.
Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
Grab the RAM module and carefully pull it straight out of its slot.
Repeat this step for the second RAM module, which is located just underneath the first RAM module.
