Ir para o conteúdo principal
HP Pavilion DV2160BR RAM Replacement
O que você precisa
  1. HP Pavilion DV2160BR RAM Replacement, RAM: passo 1, imagem 1 %32 HP Pavilion DV2160BR RAM Replacement, RAM: passo 1, imagem 2 %32
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: passo 2, imagem 1 %32 HP Pavilion DV2160BR RAM Replacement: passo 2, imagem 2 %32
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: passo 3, imagem 1 %32 HP Pavilion DV2160BR RAM Replacement: passo 3, imagem 2 %32 HP Pavilion DV2160BR RAM Replacement: passo 3, imagem 3 %32
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Conclusão
Shannon
Membro desde: 04/11/13
55 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-66, Johann Spring 2013 Membro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 380
