Ir para o conteúdo principal
HP Pavilion DV2160BR Hard Drive Replacement
O que você precisa
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: passo 2, imagem 1 %32
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion DV2160BR Hard Drive Replacement: passo 3, imagem 2 %32
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion DV2160BR Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion DV2160BR Hard Drive Replacement: passo 5, imagem 3 %32
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Conclusão
Uma outra pessoa concluiu este guia.
Shannon
Membro desde: 04/11/13
55 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-66, Johann Spring 2013 Membro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 555
