Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
In this guide you will learn how to remove the DVD±RW Drive from an HP Pavilion DV2160BR.
  1. Start with the bottom of the laptop facing up.
    • Start with the bottom of the laptop facing up.
  2. Locate the battery compartment at the rear of the device. There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  4. Locate the  locking screw which is located in a recessed hole on the underside of the laptop.
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  5. Locate the CD drive tray release hole on the front of the drive. Straighten a paper clip and push it gently into the CD drive tray release hole.
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  6. Grasp the side edges of the drive tray.
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  7. Locate the mounting bracket which is attached to the back of  the drive.
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon MacDonald
Membro desde: 12-03-2014
239 Reputação
2 Guias de autoria
Equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 165
