Ir para o conteúdo principal
HP Pavilion DM4 Hard Drive Replacement
O que você precisa
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: passo 1, imagem 1 %32 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: passo 1, imagem 2 %32
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: passo 2, imagem 1 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 2, imagem 2 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 2, imagem 3 %32
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: passo 3, imagem 1 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 3, imagem 2 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 3, imagem 3 %32
    • Unscrew the hidden screws in order to remove the hard drive cover.
  4. HP Pavilion DM4 Hard Drive  Replacement: passo 4, imagem 1 %32
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: passo 5, imagem 1 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 5, imagem 2 %32 HP Pavilion DM4 Hard Drive  Replacement: passo 5, imagem 3 %32
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: passo 6, imagem 1 %32
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
Conclusão
8 outras pessoas executaram este guia.
Um comentário
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 7,960
