Ir para o conteúdo principal
HP Pavilion DM3-3010US Sound Card Replacement
O que você precisa
  1. HP Pavilion DM3-3010US Sound Card Replacement, Sound Card: passo 1, imagem 1 %32
    • Place the laptop upside down on a stable surface and locate the battery ejection switch.
  2. HP Pavilion DM3-3010US Sound Card Replacement: passo 2, imagem 1 %32
    • Eject the battery by sliding the switch sideways.
  3. HP Pavilion DM3-3010US Sound Card Replacement: passo 3, imagem 1 %32
    • Pull the battery outwards.
  4. HP Pavilion DM3-3010US Sound Card Replacement: passo 4, imagem 1 %32
    • Remove the 2 plastic panels covering the internals of the laptop.
    • The rectangular panel can be removed by sliding the latch.
    • The square panel is removable once the battery is removed.
  5. HP Pavilion DM3-3010US Sound Card Replacement: passo 5, imagem 1 %32
    • Removing the square panel reveals the location of the hard drive.
  6. HP Pavilion DM3-3010US Sound Card Replacement: passo 6, imagem 1 %32
    • Locate the two screws located on the side of the hard drive mounting hardware.
    • This is accessible from the back of the laptop, where the battery was located.
  7. HP Pavilion DM3-3010US Sound Card Replacement: passo 7, imagem 1 %32
    • Locate the 4 additional screws on the top of the mounting hardware for the hard drive.
    • Remove and set aside these screws.
  8. HP Pavilion DM3-3010US Sound Card Replacement: passo 8, imagem 1 %32
    • Pay attention to the SATA cable connecting the hard drive to the motherboard. It can be damaged if handled roughly.
    • Pull the SATA cable out of its receptacle and set the hard drive aside.
  9. HP Pavilion DM3-3010US Sound Card Replacement: passo 9, imagem 1 %32
    • The picture shows the HP Pavilion DM3-3000 Series Audio USB Card Reader Board w/Cable.
    • With the hard drive removed, open the laptop and set it down in the position for normal use.
    • Locate the seam between the top panel of the laptop and the frame.
    • The seam is on the left side of the laptop when the screen is facing you.
    • Pull the top cover, including keyboard, up from the left side of the laptop.
  10. HP Pavilion DM3-3010US Sound Card Replacement: passo 10, imagem 1 %32
    • Dismount the audio driver by removing the 4 highlighted screws.
    • The audio driver is located on the right side of the laptop while the screen is facing you.
  11. HP Pavilion DM3-3010US Sound Card Replacement: passo 11, imagem 1 %32
    • The audio driver and surrounding components are susceptible to damage if handled incorrectly.
    • Carefully pull the audio driver upwards, away from the motherboard.
    • The laptop is now ready to receive the replacement audio driver.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,721
