Ir para o conteúdo principal
HP Pavilion DM3-3010US Keyboard Replacement
O que você precisa
  1. HP Pavilion DM3-3010US Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip laptop to bottom side and locate the battery eject switch.
  2. HP Pavilion DM3-3010US Keyboard Replacement: passo 2, imagem 1 %32
    • Slide switch inward, then pull the battery away from its slot.
    • Once free, place the battery to the side.
  3. HP Pavilion DM3-3010US Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Flip the laptop over and open it so the keyboard is visible.
    • Using a spudger, gently pry the keyboard away from the laptop using the three indicated markers.
    • Continue gently pulling the keyboard away from the laptop until it completely detaches.
  4. HP Pavilion DM3-3010US Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion DM3-3010US Keyboard Replacement: passo 4, imagem 2 %32
    • Once the keyboard is completely detached, locate the ribbon housing inside the laptop.
    • Gently pull the ribbon cable from the connector housing.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,195
