Ir para o conteúdo principal
HP Pavilion DM3-3010US Hard Drive Replacement
O que você precisa
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: passo 2, imagem 1 %32
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion DM3-3010US Hard Drive Replacement: passo 4, imagem 2 %32
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion DM3-3010US Hard Drive Replacement: passo 5, imagem 2 %32
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 1,834
