Ir para o conteúdo principal
HP Pavilion 17-g192dx Disassembly
O que você precisa
  1. HP Pavilion 17-g192dx Disassembly, Battery: passo 1, imagem 1 %32 HP Pavilion 17-g192dx Disassembly, Battery: passo 1, imagem 2 %32 HP Pavilion 17-g192dx Disassembly, Battery: passo 1, imagem 3 %32
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Disassembly: passo 2, imagem 1 %32
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Disassembly: passo 3, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 3, imagem 2 %32
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Disassembly, laptop: passo 4, imagem 1 %32
    • Using the metal spudger, pry up the screw covers.
  5. HP Pavilion 17-g192dx Disassembly: passo 5, imagem 1 %32
    • Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
  6. HP Pavilion 17-g192dx Disassembly: passo 6, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 6, imagem 2 %32
    • Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
  7. HP Pavilion 17-g192dx Disassembly: passo 7, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 7, imagem 2 %32 HP Pavilion 17-g192dx Disassembly: passo 7, imagem 3 %32
    • Using an iFixit opening tool, push the disc drive away from the outer case.
    • Once the disk drive is out far enough, it easily slides out.
  8. HP Pavilion 17-g192dx Disassembly: passo 8, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 8, imagem 2 %32 HP Pavilion 17-g192dx Disassembly: passo 8, imagem 3 %32
    • Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
    • Using a metal spudger, lift up on the back resting plate until it pops off.
  9. HP Pavilion 17-g192dx Disassembly: passo 9, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 9, imagem 2 %32
    • Remove the two 7 mm screws behind the plate using a Phillips #00 screwdriver.
  10. HP Pavilion 17-g192dx Disassembly: passo 10, imagem 1 %32 HP Pavilion 17-g192dx Disassembly: passo 10, imagem 2 %32 HP Pavilion 17-g192dx Disassembly: passo 10, imagem 3 %32
    • Pry up on the case with an iFixit opening tool until you can feel a snap.
    • Pry around the remainder until you can separate the case from the keyboard with your hands.
    • Gently separate the two.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 1,486
