Ir para o conteúdo principal
HP Pavilion 17-f127ds Optical Drive Replacement
O que você precisa
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, imagem 3 %32
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: passo 2, imagem 1 %32 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: passo 3, imagem 1 %32
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Conclusão
Stephen Brown
Membro desde: 10/18/17
201 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S3-G1, Liner Fall 2017 Membro de UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
Membros da 5
Autoria de 4 guias
Um comentário
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 934
