Ir para o conteúdo principal
HP Pavilion 17-f127ds Keyboard Replacement
O que você precisa
  1. HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: passo 2, imagem 2 %32
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion 17-f127ds Keyboard Replacement: passo 3, imagem 2 %32 HP Pavilion 17-f127ds Keyboard Replacement: passo 3, imagem 3 %32
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
Conclusão
Alissa Tu
Membro desde: 10/18/17
284 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S3-G1, Liner Fall 2017 Membro de UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
Membros da 5
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 1,118
