Introdução
Use this guide is need to replace the keyboard of your HP Pavilion 17-e146us. The keyboard is the component of the laptop used to type. If the keyboard is faulty certain letters or portions of the keyboard may not work, and therefore it is difficult to type when necessary. This guide will show how to replace a faulty/broken keyboard with a new keyboard. Please be aware that the keyboard is attached to the motherboard and is not an easy process to remove.
O que você precisa
Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
