Ir para o conteúdo principal
HP Pavilion 17-e117dx Service Panel Replacement
O que você precisa
  1. HP Pavilion 17-e117dx Service Panel Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Service Panel Replacement: passo 2, imagem 1 %32 HP Pavilion 17-e117dx Service Panel Replacement: passo 2, imagem 2 %32
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Service Panel Replacement, Service Panel: passo 3, imagem 1 %32 HP Pavilion 17-e117dx Service Panel Replacement, Service Panel: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Service Panel Replacement: passo 4, imagem 1 %32
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Service Panel Replacement: passo 5, imagem 1 %32
    • Remove the service panel.
Conclusão
Marcel Amazan
Membro desde: 03/24/19
576 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 350
