Introdução
You may need to replace your laptop’s hard drive when your laptop has a bad virus/corrupted files. However, it would be better to test other solutions first because you will lose all the files saved to your computer, unless you back them up to the cloud or an external drive.
Before you begin this procedure, make sure the laptop is powered off and there is nothing plugged into the computer. Also, your hands will need to be clean and dry.
O que você precisa
Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
