Ir para o conteúdo principal
HP Pavilion 17 TS Hard Drive Replacement
O que você precisa
  1. HP Pavilion 17 TS Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 17 TS Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 17 TS Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: passo 2, imagem 1 %32 HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: passo 2, imagem 2 %32 HP Pavilion 17 TS Hard Drive Replacement, Rear Cover: passo 2, imagem 3 %32
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 HP Pavilion 17 TS Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove the two silver phillips screws from the hard drive.
    • Using the plastic tab, remove the hard drive from its socket.
    • Unplug the hard drive from the wire connecting it to the motherboard.
Conclusão
Sean Croft
Membro desde: 03/25/16
739 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-6, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 2,305
