Ir para o conteúdo principal
HP Pavilion 17 TS Disk Drive Replacement
O que você precisa
  1. HP Pavilion 17 TS Disk Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 17 TS Disk Drive Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 17 TS Disk Drive Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: passo 2, imagem 1 %32 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: passo 2, imagem 2 %32 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: passo 2, imagem 3 %32
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: passo 3, imagem 1 %32 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: passo 3, imagem 2 %32 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: passo 3, imagem 3 %32
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
Conclusão
Eric Sowersby
Membro desde: 03/25/16
413 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 551
