Ir para o conteúdo principal
HP Pavilion 15-p214dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: passo 1, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: passo 1, imagem 2 %32 HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: passo 1, imagem 3 %32
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 2, imagem 2 %32
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Hard Drive Replacement, Top Cover: passo 3, imagem 1 %32
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 5, imagem 3 %32
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 6, imagem 2 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 6, imagem 3 %32
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Hard Drive Replacement: passo 7, imagem 1 %32
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Hard Drive Replacement: passo 8, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 8, imagem 2 %32
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Hard Drive Replacement: passo 9, imagem 1 %32
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Hard Drive Replacement: passo 10, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement: passo 10, imagem 2 %32
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
  11. HP Pavilion 15-p214dx Hard Drive Replacement, Hard Drive: passo 11, imagem 1 %32 HP Pavilion 15-p214dx Hard Drive Replacement, Hard Drive: passo 11, imagem 2 %32
    • Open the clip holding the USB connector cable in place, then slide the cable out of the clip.
    • Open the clip that holds the hard drive cable in place, then remove the cable from that port.
    • Tilt the hard drive so that it slopes down to the right, then pull it out of the computer.
    • You should handle the hard drive carefully, since dropping, shaking, or exposing the drive to static can cause damage.
Conclusão
Uma outra pessoa concluiu este guia.
Patrick Seaver
Membro desde: 03/25/19
1.001 Reputação
Autoria de 8 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,345
