Ir para o conteúdo principal
HP Pavilion 15-p214dx Disk Drive Replacement
O que você precisa
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, imagem 1 %32 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, imagem 2 %32 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: passo 1, imagem 3 %32
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-p214dx Disk Drive Replacement: passo 2, imagem 2 %32
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Conclusão
Patrick Seaver
Membro desde: 03/25/19
1.001 Reputação
Autoria de 8 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 247
