Introdução
If you need to remove or replace your computer’s disk drive, follow this guide. To do this, you will need a Philips #0 screwdriver head and maybe a plastic opening tool if you have short fingernails. The disk drive is held in place by a single screw, so there will be no difficult steps.
O que você precisa
Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
Remove this screw using a Philips #0 screwdriver.
