Ir para o conteúdo principal
HP Pavilion 15-p046nr Integrated Keyboard Replacement
O que você precisa
  1. HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 2, imagem 2 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 2, imagem 3 %32
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: passo 3, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: passo 3, imagem 2 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement, Integrated Keyboard: passo 3, imagem 3 %32
    • Remove screw covers from the hinge covers on the upper left and right side.
    • Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
    • Remove hinge covers by pulling up and out on the top of the cover.
  4. HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 4, imagem 2 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 4, imagem 3 %32
    • Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
    • Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
    • Grab the disk drive on the left side and pull the disk drive out completely.
    • Flip the laptop over and open the display.
  5. HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 5, imagem 2 %32
    • Run the plastic opening tool along the entire edge of the keyboard to separate the keyboard from the base of the laptop.
    • Gently lift the keyboard tray up.
    • Use care to lift the keyboard off of the device. The keyboard is still attached by ribbon cables.
  6. HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 6, imagem 2 %32
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the two ribbon cables connecting the keyboard to the device.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the ribbon cable and gently pull away from the socket.
    • To reinstall, insert the ribbon cable into the connector and close the flap on the black line.
  7. HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 7, imagem 2 %32 HP Pavilion 15-p046nr Integrated Keyboard Replacement: passo 7, imagem 3 %32
    • Lift the keyboard up and away from the device.
    • Removing the keyboard exposes the motherboard and its sensitive components. Ensure no tools or items are set on the motherboard or it could cause damage.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 1,389
