Ir para o conteúdo principal
HP Pavilion 15-p046nr Disk Drive Replacement
O que você precisa
  1. HP Pavilion 15-p046nr Disk Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Disk Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-p046nr Disk Drive Replacement: passo 2, imagem 2 %32 HP Pavilion 15-p046nr Disk Drive Replacement: passo 2, imagem 3 %32
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: passo 3, imagem 1 %32 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: passo 3, imagem 2 %32 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: passo 3, imagem 3 %32
    • Remove one 7 mm, Phillips #00 screw from the back panel.
    • Open the disk drive by gently pulling on the drive.
    • Pull the disk drive out and away from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 248
