Ir para o conteúdo principal
HP Pavilion 15-p043cl Repair Optical Drive Replacement
O que você precisa
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 2, imagem 2 %32
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, imagem 2 %32 HP Pavilion 15-p043cl Repair Optical Drive Replacement: passo 3, imagem 3 %32
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 58
