Ir para o conteúdo principal
HP Pavilion 15-n210dx Keyboard Replacement
O que você precisa
  1. HP Pavilion 15-n210dx Keyboard  Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, imagem 1 %32 HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, imagem 2 %32 HP Pavilion 15-n210dx Keyboard  Replacement: passo 2, imagem 3 %32
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Keyboard  Replacement, Keyboard: passo 3, imagem 1 %32
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Keyboard  Replacement: passo 4, imagem 1 %32
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Keyboard  Replacement: passo 5, imagem 1 %32 HP Pavilion 15-n210dx Keyboard  Replacement: passo 5, imagem 2 %32
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
Conclusão
Brayan Rivas
Membro desde: 10/25/21
97 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-8, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G8
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 276
