Introdução
This guide will help you be able to take out and replace the Hard drive in the HP Pavilion 15-d017cl. A hard disk drive is a non-volatile memory hardware device that permanently stores and retrieves data on a computer. This guide requires a Phillips #1 screwdriver, spudger, tweezers, and an iFixit opening tool.
O que você precisa
Flip the laptop onto its back in order to have access to the back "L" shaped panel.
Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
4 outras pessoas executaram este guia.
