Ir para o conteúdo principal
HP Pavilion 15-cc023cl Hard Drive Replacement
O que você precisa
  1. HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 2, imagem 1 %32
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-cc023cl Hard Drive Replacement: passo 3, imagem 2 %32
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion 15-cc023cl Hard Drive Replacement: passo 4, imagem 2 %32
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. HP Pavilion 15-cc023cl Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to pry the hard drive out.
  7. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 7, imagem 1 %32
    • Disconnect the hard drive cable.
  8. HP Pavilion 15-cc023cl Hard Drive Replacement: passo 8, imagem 1 %32
    • Lift the plastic wedges up on both sides of the hard drive.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 4,387
