Introdução
Use this guide to replace the touchpad of the HP Pavilion 15-ca2073cl.
Before you begin to replace the touchpad, make sure the laptop is powered off.
O que você precisa
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
Ferramenta utilizada neste passo:Tweezers$4.99
Once the battery is removed, use the tweezers to disconnect the smaller ribbon cable that is attached to the touchpad and motherboard.
Proceed to disconnect the larger ribbon cable that is attached to the touchpad and motherboard.
