Introdução
Overtime, the battery in a device will degrade and lose functionality. If the battery in your device is degrading, you may find that your device won’t charge or fails to hold a charge. In addition, you may notice that your device doesn’t turn on. If you suspect that the battery is failing in your device, it may be time to replace it.
This guide outlines how to remove HP Pavilion 15-ca2073cl battery. You will need to open the device's back panel as the battery is located inside the case.
O que você precisa
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
