Ir para o conteúdo principal
HP Pavilion 15-bk020wm Touchpad Replacement
O que você precisa
  1. HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: passo 1, imagem 1 %32 HP Pavilion 15-bk020wm Touchpad Replacement, Keyboard Cover: passo 1, imagem 2 %32
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchpad Replacement: passo 2, imagem 1 %32 HP Pavilion 15-bk020wm Touchpad Replacement: passo 2, imagem 2 %32 HP Pavilion 15-bk020wm Touchpad Replacement: passo 2, imagem 3 %32
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchpad Replacement: passo 3, imagem 1 %32
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: passo 4, imagem 1 %32 HP Pavilion 15-bk020wm Touchpad Replacement, Touchpad: passo 4, imagem 2 %32
    • After taking the keyboard cover off of the device, flip it over and locate the purple and white cable.
    • Using the plastic opening tool, flip the ZIF connector open and detach the touchpad cable.
  5. HP Pavilion 15-bk020wm Touchpad Replacement: passo 5, imagem 1 %32 HP Pavilion 15-bk020wm Touchpad Replacement: passo 5, imagem 2 %32 HP Pavilion 15-bk020wm Touchpad Replacement: passo 5, imagem 3 %32
    • Unscrew the three screws at the bottom of the touchpad using the #00 Phillips screwdriver.
    • Life the bottom security piece off of the touchpad.
    • Unscrew the three top screws using the same #00 Phillips screwdriver.
  6. HP Pavilion 15-bk020wm Touchpad Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool, lift the touchpad off of the keyboard cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 31
Duração total: 7,428
