Ir para o conteúdo principal
HP Pavilion 15-ba003ds Screen Replacement
O que você precisa
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement, Screen: passo 1, imagem 3 %32
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 2, imagem 3 %32
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 3, imagem 3 %32
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: passo 4, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 4, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 4, imagem 3 %32
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: passo 5, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 5, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 5, imagem 3 %32
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: passo 6, imagem 1 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 6, imagem 2 %32 HP Pavilion 15-ba003ds Screen Replacement: passo 6, imagem 3 %32
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: passo 7, imagem 1 %32
    • Lift the screen away from the laptop.
Conclusão
Joseph Chia
Membro desde: 01/14/20
355 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 321
