Ir para o conteúdo principal
HP Pavilion 15-ba003ds RAM Replacement
O que você precisa
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: passo 2, imagem 1 %32
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds RAM Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement: passo 3, imagem 2 %32
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds RAM Replacement: passo 4, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement: passo 4, imagem 2 %32
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 2 %32 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 3 %32
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, imagem 2 %32
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
Conclusão
Krushnam Badami
Membro desde: 01/14/20
342 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 322
