Ir para o conteúdo principal
HP Pavilion 15-ba003ds Charging Port Replacement
O que você precisa
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: passo 2, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: passo 2, imagem 2 %32 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: passo 2, imagem 3 %32
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: passo 3, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: passo 4, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 4, imagem 2 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 4, imagem 3 %32
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: passo 5, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 5, imagem 2 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 5, imagem 3 %32
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: passo 6, imagem 1 %32
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 7, imagem 2 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 7, imagem 3 %32
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: passo 8, imagem 1 %32 HP Pavilion 15-ba003ds Charging Port Replacement: passo 8, imagem 2 %32
    • Use a spudger to pry off the charging port.
Conclusão
LI XU
Membro desde: 01/14/20
334 Reputação
Autoria de 2 guias
Equipe
Um comentário
how much does it cost to replace a laptop charging port
Ebele Athekame - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 20
Duração total: 2,389
