Ir para o conteúdo principal
HP Pavilion 15-b109wm Fan Replacement
O que você precisa
  1. HP Pavilion 15-b109wm Fan Replacement, Battery: passo 1, imagem 1 %32
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Fan Replacement: passo 2, imagem 1 %32
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Fan Replacement: passo 3, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement: passo 3, imagem 2 %32 HP Pavilion 15-b109wm Fan Replacement: passo 3, imagem 3 %32
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Fan Replacement: passo 4, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement: passo 4, imagem 2 %32 HP Pavilion 15-b109wm Fan Replacement: passo 4, imagem 3 %32
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Fan Replacement, Keyboard: passo 5, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement, Keyboard: passo 5, imagem 2 %32
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Fan Replacement: passo 6, imagem 1 %32
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Fan Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Fan Replacement: passo 8, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Fan Replacement: passo 9, imagem 1 %32
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Fan Replacement: passo 10, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement: passo 10, imagem 2 %32 HP Pavilion 15-b109wm Fan Replacement: passo 10, imagem 3 %32
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, imagem 2 %32 HP Pavilion 15-b109wm Fan Replacement, Fan: passo 11, imagem 3 %32
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Fan Replacement: passo 12, imagem 1 %32 HP Pavilion 15-b109wm Fan Replacement: passo 12, imagem 2 %32 HP Pavilion 15-b109wm Fan Replacement: passo 12, imagem 3 %32
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Fan Replacement: passo 13, imagem 1 %32
    • Carefully remove the fan from its slot.
Conclusão
Stephen Gacioch
Membro desde: 10/26/18
437 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 12
Duração total: 465
