Ir para o conteúdo principal
HP Pavilion 15-ay041wm Optical Disc Drive Replacement
O que você precisa
  1. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 2, imagem 2 %32
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 3, imagem 3 %32
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Optical Disc Drive Replacement, Disc Drive: passo 4, imagem 1 %32
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, imagem 1 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, imagem 2 %32 HP Pavilion 15-ay041wm Optical Disc Drive Replacement: passo 5, imagem 3 %32
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
85.248 Reputação
Autoria de 215 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.078 guias
Um comentário
Might add “Optical” to drive title to save some confusion.
mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 606
