Ir para o conteúdo principal
HP Pavilion 15-au123cl RAM Replacement
O que você precisa
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: passo 2, imagem 1 %32 HP Pavilion 15-au123cl RAM Replacement: passo 2, imagem 2 %32
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl RAM Replacement: passo 3, imagem 1 %32 HP Pavilion 15-au123cl RAM Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl RAM Replacement: passo 4, imagem 1 %32 HP Pavilion 15-au123cl RAM Replacement: passo 4, imagem 2 %32
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl RAM Replacement: passo 5, imagem 1 %32 HP Pavilion 15-au123cl RAM Replacement: passo 5, imagem 2 %32 HP Pavilion 15-au123cl RAM Replacement: passo 5, imagem 3 %32
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: passo 6, imagem 1 %32 HP Pavilion 15-au123cl RAM Replacement, RAM: passo 6, imagem 2 %32
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: passo 7, imagem 1 %32
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
Conclusão
Mohammad Gardezi
Membro desde: 10/17/17
1.420 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
Membros da 2
Autoria de 6 guias
Um comentário
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 1,258
