Introdução
This guide will display how to replace the motherboard of the HP Pavilion 15-au123cl Laptop. The replacement is not hard, but will require the removal of the fan, network card, and battery beforehand.
O que você precisa
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
The network card is located at the top left corner of the motherboard.
Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
Firmly disconnect the fan from the motherboard.
Remove the three screws from the fan using a Philips #0 Screwdriver.
3 outras pessoas executaram este guia.
Um comentário
buenas tardes : Nesecito saber donde puedo conseguir el Motherboard para una HP Pavilion Y1N95UA 15-AU123CL descrito en este posteo ..
Saludos Gabriel Angel..!!!
