Ir para o conteúdo principal
HP Pavilion 15-au123cl Fan Replacement
O que você precisa
  1. HP Pavilion 15-au123cl Fan Replacement, Fan: passo 1, imagem 1 %32 HP Pavilion 15-au123cl Fan Replacement, Fan: passo 1, imagem 2 %32
    • Remove the ten screws from the back case with a Phillips #0 screwdriver.
    • Using a plastic opening tool, pry the CD drive from the computer.
    • Remove the back panel from the computer.
  2. HP Pavilion 15-au123cl Fan Replacement: passo 2, imagem 1 %32
    • Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
    • Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
    • Gently disconnect the fan cable cable.
    • Remove the fan.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 502
