Introdução
If you are noticing the settings are wrong on the BIOS, you will want to follow this guide to reset the BIOS settings. The CMOS battery holds BIOS settings so booting up the computer after removing the battery should fix all BIOS issues.
  1. Make sure the laptop is off and unplugged before starting.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. Using the plastic opening tool, remove the back cover of the laptop. It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  6. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  7. The CMOS battery is located toward the middle left area of the motherboard. Using the spudger, lift the CMOS battery out of its plastic casing.
    • The CMOS battery is located toward the middle left area of the motherboard.
    • Using the spudger, lift the CMOS battery out of its plastic casing.
  8. Fully remove the CMOS battery from the motherboard.
    • Fully remove the CMOS battery from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Mohammad Gardezi
808 reputação
6 Guides authored
Equipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 19
Últimos 30 dias: 122
Todo: 1,095
