Ir para o conteúdo principal
HP Pavilion 15-au123cl CD Drive Replacement
O que você precisa
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 2, imagem 2 %32
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: passo 4, imagem 1 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 4, imagem 2 %32
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: passo 5, imagem 1 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 5, imagem 2 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 5, imagem 3 %32
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: passo 6, imagem 1 %32
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: passo 7, imagem 1 %32 HP Pavilion 15-au123cl CD Drive Replacement: passo 7, imagem 2 %32
    • Disconnect the CD drive from the motherboard connector on the left.
Conclusão
Mohammad Gardezi
Membro desde: 10/17/17
1.420 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 550
