Ir para o conteúdo principal
HP Pavilion 15-ab243cl RAM Stick Replacement
O que você precisa
  1. HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 2, imagem 3 %32
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 3, imagem 2 %32
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: passo 4, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: passo 4, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement, Laptop Case: passo 4, imagem 3 %32
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 5, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 5, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 5, imagem 3 %32
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 6, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 6, imagem 2 %32
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 7, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 8, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 8, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 8, imagem 3 %32
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: passo 9, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: passo 9, imagem 2 %32 HP Pavilion 15-ab243cl RAM Stick Replacement, RAM Stick: passo 9, imagem 3 %32
    • Locate the RAM stick, will be next to hard drive. Unclip the two silver retainers on each side.
  10. HP Pavilion 15-ab243cl RAM Stick Replacement: passo 10, imagem 1 %32 HP Pavilion 15-ab243cl RAM Stick Replacement: passo 10, imagem 2 %32
    • The card will pop up when silver retainers are released. The card is ready to remove, pull straight out.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S6-G3, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S6G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 600
