Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to access the cooling fan and replace it. The cooling fan is necessary to keep your laptop from overheating.
O que você precisa
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place.
