Introdução
This is a simple and straight forward procedure to replace the CD-Drive on your device. If your CD-drive has failed and will no longer read discs, then following this guide will help you regain a functioning drive.
Ferramentas
Peças
Nenhum componente especificado.
Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver.
Uma outra pessoa concluiu este guia.
