Ir para o conteúdo principal
HP Pavilion 15-ab165us RAM Replacement
O que você precisa
  1. HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us RAM Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us RAM Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us RAM Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us RAM Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us RAM Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us RAM Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us RAM Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us RAM Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us RAM Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us RAM Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us RAM Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us RAM Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us RAM Replacement, RAM: passo 9, imagem 1 %32
    • Locate RAM.
  10. HP Pavilion 15-ab165us RAM Replacement: passo 10, imagem 1 %32
    • Pull the tension arms away from both sides the RAM.
  11. HP Pavilion 15-ab165us RAM Replacement: passo 11, imagem 1 %32
    • Pull RAM away from the RAM slot.
  12. HP Pavilion 15-ab165us RAM Replacement: passo 12, imagem 1 %32
    • Repeat this process for the next stick of RAM.
Conclusão
3 outras pessoas executaram este guia.
Myai Nguyen
Membro desde: 10/20/17
203 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 2,585
