Ir para o conteúdo principal
HP Pavilion 15-ab165us Motherboard Replacement
O que você precisa
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: passo 10, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 10, imagem 2 %32
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: passo 11, imagem 1 %32
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: passo 12, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 12, imagem 2 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 12, imagem 3 %32
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: passo 13, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 13, imagem 2 %32
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: passo 14, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 14, imagem 2 %32
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: passo 15, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 15, imagem 2 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 15, imagem 3 %32
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: passo 17, imagem 1 %32
  18. HP Pavilion 15-ab165us Motherboard Replacement: passo 18, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 18, imagem 2 %32
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: passo 19, imagem 1 %32
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: passo 20, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 20, imagem 2 %32
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: passo 21, imagem 1 %32 HP Pavilion 15-ab165us Motherboard Replacement: passo 21, imagem 2 %32
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
Conclusão
3 outras pessoas executaram este guia.
Dillon Hubble
Membro desde: 10/20/17
653 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 1,580
