Ir para o conteúdo principal
HP Pavilion 15-ab165us Fan Replacement
O que você precisa
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: passo 9, imagem 1 %32
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 3 %32
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: passo 11, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 11, imagem 2 %32
    • Remove the fan from the motherboard.
Conclusão
Chad Christy
Membro desde: 11/07/19
205 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G1, Harley Fall 2019 Membro de IUPUI, Team S3-G1, Harley Fall 2019
IUPUI-HARLEY-F19S3G1
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 637
