Ir para o conteúdo principal
HP Pavilion 15-ab165us Battery and Back Cover Replacement
O que você precisa
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
Conclusão
10 outras pessoas executaram este guia.
Dillon Hubble
Membro desde: 10/20/17
653 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
Membros da 5
Autoria de 14 guias
Um comentário
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 65
Duração total: 66,467
