Ir para o conteúdo principal
HP Pavilion 15-ab121dx Key Hinge Replacement
O que você precisa
  1. HP Pavilion 15-ab121dx Key Hinge Replacement, Key Hinge: passo 1, imagem 1 %32
    • Position the plastic spudger beneath the center of the keycap.
  2. HP Pavilion 15-ab121dx Key Hinge Replacement: passo 2, imagem 1 %32
    • Continue to insert the plastic spudger inward while simultaneously applying upward pressure.
  3. HP Pavilion 15-ab121dx Key Hinge Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 3, imagem 3 %32
    • Please be very cautious for the next step, as the key hinge is very fragile and prone to breaking easily.
    • Insert the spudger underneath the key hinge and pry it upward.
  4. HP Pavilion 15-ab121dx Key Hinge Replacement: passo 4, imagem 1 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 4, imagem 2 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 4, imagem 3 %32
    • Take note of the metal hooks once the key hinge has been removed.
    • Hook the outer two holes of the new key hinge to the top metal hooks on the keyboard.
  5. HP Pavilion 15-ab121dx Key Hinge Replacement: passo 5, imagem 1 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 5, imagem 2 %32
    • Once aligned, use one finger to push the bottom of the hinge.
  6. HP Pavilion 15-ab121dx Key Hinge Replacement: passo 6, imagem 1 %32 HP Pavilion 15-ab121dx Key Hinge Replacement: passo 6, imagem 2 %32
    • Align the keycap as accurately as possible and press down on the keycap until it clicks into place.
Linha de Chegada
Perla Reyes
Membro desde: 03/07/24
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 41
