Introdução
This replacement will require the use of prying tools and screwdrivers. It can completed with moderate difficulty. Make sure you have a moderate chunk of time to complete this task. You will need a clear work surface. Replacing the cooling fan can often solve problems like overheating.
O que você precisa
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
