Ir para o conteúdo principal
HP Pavilion 15-AB153NR CD/DVD Drive Replacement
O que você precisa
  1. HP Pavilion 15-AB153NR CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  2. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  3. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-AB153NR CD/DVD Drive Replacement: passo 3, imagem 2 %32
    • Slide the drive out from the right side of the device.
Conclusão
Nicole Vachon
Membro desde: 03/21/19
926 Reputação
Autoria de 7 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 881
